k member and solid mount questions
Old Sep 14, 2008 | 10:55 PM
rubbersdown's Avatar
Default k member and solid mount questions
A few question.
1. If I run a stock K member with solid motor mounts, what size DP can I fit?
2. If I run a PA K member with solid mounts, what size DP can I fit?
3. Same as above but a spohn k member.
Old Sep 15, 2008 | 06:23 AM
veee8's Avatar
I run the PA with Spohn solid motor mounts and have a 5" DP run down the passenger side and dumps after the bellhousing, it is tight but does fit. Of course my headers help facilitate this.
Old Sep 15, 2008 | 10:18 AM
BMR Tech's Avatar
If you are looking mostly for down pipe room we have a k-member designed with just that in mind. Let me know if you have any questions I can help answer
Attached Thumbnails k member and solid mount questions-311089457.jpg   k member and solid mount questions-311089470.jpg   k member and solid mount questions-5_dp_1.jpg   k member and solid mount questions-5_dp_2.jpg   k member and solid mount questions-ls1-turbo-k-member-3.jpg
