Got the Turbo and the A2W IC mounted
Old Sep 29, 2008 | 03:42 PM
bumpin_records's Avatar
Tell me this having your intercooler mounted there, would it sweat and start dripping water being the heat on the outside of the cooler and the cold on the inside of it cause im real interested in mounting mine in the same place?
Old Sep 29, 2008 | 04:42 PM
Steve Burger's Avatar
LS1TECH Sponsor
It should not sweat. I have seen a lot of liquid exchangers in the front.
Old Sep 29, 2008 | 04:44 PM
Mekkadon's Avatar
Got 2048 x 1920 resolution? Huge pics....
Old Sep 29, 2008 | 05:00 PM
DanZ28's Avatar
Dan
Old Oct 14, 2008 | 04:23 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Bump for my chassis guy.
Old Oct 14, 2008 | 06:37 PM
onfire's Avatar
Coal Mining Director
What's the specs on the A/W core....looks small.
Old Oct 15, 2008 | 06:57 AM
LS1TECH Sponsor
It is the Chiseled 2000 HP core.
Old Oct 15, 2008 | 08:58 AM
onfire's Avatar
Get us some data...I might be interested if you can custom make the inlets/outlets.
What's the pressure drop at 2000cfm or 180lbs/min?
What's the thermal drop at 2000cfm 400F inlet if 50F water is used with the 5.x gallon Chisel tank and pump?
TIA
Old Oct 17, 2008 | 05:00 PM
LS1TECH Sponsor
Sorry for the delay, I've been out of town. Here is what I have on the Garrett cores used. This one is for a 1000 hp core.
The air-to-water cores were run with the following parameters:
Minimum Effectiveness = 70%
Boost pressure = 2.0 Bar
Charge inlet air temp = 350F
Charge outlet temp = 100F
Cooling fluid = 75F
Cooling fluid flow rate = 10gpm
Max flow = 100 lbs/min
pressure drop = 0.47 psi
I've got customers running them with temps in the 70-80's at the end of the runs,
Old Oct 17, 2008 | 10:00 PM
onfire's Avatar
I'll get you some dimensions.
Old Oct 18, 2008 | 10:06 AM
LS1TECH Sponsor
Sounds good.
