6.0 T-76 turbo setup
Old Sep 24, 2008 | 10:38 PM
ls1408cp's Avatar
true and i think it will be fun pushing it to its limits. You dont have to run it full *** blast all the time.
Old Sep 24, 2008 | 10:46 PM
kbracing96's Avatar
Here's a little tip if your wanting to run stock jy motors. Look for 05 and newer 5.3 and 6l. They have the stronger LS2 style rods in them.
Old Sep 24, 2008 | 10:55 PM
ls1408cp's Avatar
wow thanks. I guess none of them have long cranks like the 6.0s?
Old Sep 24, 2008 | 10:58 PM
kbracing96's Avatar
The only long crank 6l I know of where made in 99-2000 and I believe they had Iron heads too.
Old Sep 24, 2008 | 11:00 PM
ls1408cp's Avatar
yes i was just making sure the 5.3s went the same.
What is the difference between a LM7, L59, and L33? Which one would be the best to use?
Old Sep 24, 2008 | 11:02 PM
extremetoy's Avatar
ive got a long 6.0l crank w/ 14,000 miles in good condition if you need one
Old Sep 24, 2008 | 11:20 PM
kbracing96's Avatar
The LM7 is the standard 5.3, the L59 is the Flex Fuel 5.3, and the L33 is the HO all aluminum 5.3
http://en.wikipedia.org/wiki/GM_Vortec_engine
Old Sep 24, 2008 | 11:39 PM
ls1408cp's Avatar
thanks again I guess i will be looking for a LM7.
Old Sep 25, 2008 | 05:35 AM
mg98ta's Avatar
This is sum good info. I think i'm gonna run the stock bottom end, race gas, and meth. Tune it and see what I can get out of it safely. I'd like ta see a high 9 sec. pass when i'm done.
Old Sep 25, 2008 | 07:38 AM
hellbents10's Avatar
LS1Tech Sponsor
All the Lq9's have good rods too. Dave took a pic of the difference in the rods last night I will post it on this thread.
Old Sep 25, 2008 | 11:13 PM
ls1408cp's Avatar
pics would be good. How do i know its an 05 or newer 5.3? Are there any marking on the outside of the motor?
Old Sep 26, 2008 | 07:19 AM
  #32
LS1Tech Sponsor
Usually if it has a cam sensor in the front its a good eng.
I can't find the pic now lol.
Old Sep 26, 2008 | 11:54 AM
  #33
ls1408cp's Avatar
so does it still have a 24x relutor wheel or a 58 in a 2005 motor or newer?
Old Sep 26, 2008 | 12:10 PM
  #34
LS1Tech Sponsor
The truck engines and the GTO's have the 24x up till 06-07, the others are all 58. Its easy to tell by the color of the sensor. Grey is 58 and black is 24.
