Bad turbo Help!!!
Old Oct 2, 2008 | 08:07 AM
o2ws8's Avatar
Default Bad turbo Help!!!
Well I had a bad turbo and I got it fixed!But it threw oil thru my exhaust what can I do to get that oil out of my exhaust.If I try and drive my car it burns the oil and it smokes and its annoying im going to take my exhaust off but what can I do to clean the inside of my exhaust?
Old Oct 2, 2008 | 09:06 AM
borninatransam's Avatar
I would say get what ever is puddled in there out that you can and the rest should burn off.
Old Oct 2, 2008 | 09:58 AM
digitalsolo's Avatar
brakleen + power washer ought to do it.
Old Oct 2, 2008 | 10:03 AM
MY99TAWS6's Avatar
It should stop sooner or later if the problem was fixed. Just take it out and do some high speed runs that should clean it out fine. I had same deal on my 92 talon. It was actually blockage in pcv system. Crankcase pressure built up.Turbo was fine after fixed the problem and smoking stopped after some high speed runs.
Old Oct 2, 2008 | 02:57 PM
o2ws8's Avatar
thanks for the responds I heard to use engine degreaser and water hose should that do it????
