Ebay kit or STS kit?
not returned via valve cover or dipstick.
that solves 50% of your problems.
the other 25% is your oil feed pump.
(restrickting oil to turbo)
the final 25% is t clamps and hoses
get those 3 perfect and it's HOLLYWOOD!
I haven't spent that much out of pocket. I sold my duals, nitrous, motor mounts, fans, msd coils, and other things to compensate. I've probably spent 1400 including my hood.
I have also been in similar power stock car. Now I don't think there is any chance in hell an NA combo matches the turbo in area under the curve. Peak numbers are one thing.
But its pretty hard to beat FI. That said a buddy with heads,camheader,bolt on ls1 did consistently beat buddies lt1 ati procharged lt1 which was basically stock aside from the procharger. But turbos make more area under the curve than centrificals. I would like to see that same ls1 go up against that near stock sts car. Bet the sts car would win.
Ebay kits can work out ok. You might be replacing turbos if they are cheap chinese crap and thinks might not fit and again it depends if the gates and blow offs are real or knock offs. There is not that much to a turbo kit really. Some piping , intercooler which of course can also vary a lot in quailty with cheap ones leaking big time or not working like they should and not fitting in the f body very well. You have blow off and gate or some turbos have internal gates. Couplers and clamps.
And of course you need fuel and tuning. Fuel is simple at lower power levels. At 5psi you can get buy with injectors and cheap racetronix intank. Tuning well you can get a predator and tune ok thats why comes with sts kits or did.
So take your pic. Head,cam,headers bolt ons work well too of course as does spray. But nothing beats the thrill of a turbo or turbos spooling up and the kick in the butt they give.
