how much power
Old Oct 9, 2008 | 01:57 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm just messin' around Zombie, I'd rather see you try stuff and read about it rather than always wonder if it would have helped.
Since the OP plans to run a 402ci, I think you could probably run a 9.xx on pump gas as long as the IAT's are not going over 150F.
You will need race gas for 1000rwhp, and i'd run at least straight 112 if not C16.
Old Oct 9, 2008 | 04:06 PM
pozesd99''s Avatar
you hit my plan right on the ball lol
yah im just trying to get a solid 9 second street car...
Old Oct 10, 2008 | 12:40 AM
VENGEANCE's Avatar
you will have 0 problem going nines with that setup at full weight. Your cam is a bit weak though, IMO. I personally would have gone much bigger. Either way you wont have any problem making 1000whp with that setup (depending on boost level), even with the auto and rear, etc etc. I think you could potentially see some 8's as well.
Old Oct 10, 2008 | 04:58 PM
pozesd99''s Avatar
cam is small?? va speed has used this same custom cam on several 402 with 88mmm making over 1200rwhp
Old Oct 11, 2008 | 02:15 PM
VENGEANCE's Avatar
Just me personally, Im nto saying your cam wont work but I would have went bigger.
