braided line in-tank?
Old Oct 21, 2008 | 10:58 PM
HossinatorSS's Avatar
Default braided line in-tank?
I'm having issues with fuel pressure, (dropping too much at WOT and bleeding out after priming) and am going to replace the intank fuel "straw" with braided line. From what I've read is -6AN the correct size for intank? and also, do I just use normal worm clamps to attach it to the two nipples?
Thanks!
Old Oct 22, 2008 | 02:49 AM
crashinaz's Avatar
I'd use the submersable rated 3/8 fuel line instead... Stainless hose clamps are fine.
Old Oct 23, 2008 | 06:24 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Braided line is not compatible in submerged applications.
I have seen numerous failures from people using braided lines in this application.
If installed correctly, there is no problem with the factory flex hose.
