Fuel spraying inside of tank
Secondly, DO NOT RUN THE PUMP PARTIALLY OUT OF THE TANK.
You are asking for an ambulance ride to the nearest burn unit. The only thing making the pump not cause an explosion due to a spark is the lack of oxygen in the fuel tank because it is displaced by all the fuel vapors. By pulling it partially out of the tank you are giving it the air it needs to cause an explosion.
