gen IV injectors???
Old Nov 4, 2008 | 02:52 PM
ls1_catera's Avatar
Default gen IV injectors???
anybody know the specs of gen IV injectors? will they fit LS1???
thanks for any help.
dan
Old Nov 4, 2008 | 04:36 PM
GA95DCMSS's Avatar
I don't remember the specs on the injectors on the L76 intakes, but I do know they have a much shorter body than the regular LS1 injectors. The connector on them is also different. The LS1 injectors use the EV1 connector (Bosch) and the Gen IV (L76) injectors use a USCAR type connector. The LS2 injectors are close, but are still short and also use the USCAR type connector.
The LS2 and L76 injectors also come with thicker O-rings.
This link may help illustrate things better.
http://www.fuelairspark.com/WhatsNew...stechsheet.pdf
Old Nov 4, 2008 | 07:57 PM
FICINJECTORS's Avatar
They wont fit, too short.
LS1 is 60mm
LS2 is 48mm
LS3 is 40mm
measured top o-ring to bottom o-ring
Old Nov 11, 2008 | 03:15 PM
blackz93's Avatar
IS that from center to center, or outside to outside, or what?
Old Nov 11, 2008 | 04:16 PM
o-ring to o-ring
