Cam-only + Dry Kit Injector Sizing
Old Nov 9, 2008 | 03:41 PM
b00sted's Avatar
Default Cam-only + Dry Kit Injector Sizing
42 lb'ers, or **** it and just get the 60s?
MS3, bolt-ons, th400, dry kit(150-200).
Old Nov 9, 2008 | 03:52 PM
JScamaro's Avatar
42 lb. injectors will be plenty. You won't need 60 lb. injectors unless you plan to go forced induction.
Old Nov 9, 2008 | 04:06 PM
b00sted's Avatar
That's what I was figuring...I'd just be pissed to spray this thing next year and max injectors out. 42 lb'ers at 58psi should flow close to what? 48-49? I'm guessing that's plenty.
Old Nov 12, 2008 | 05:21 PM
bad6as's Avatar
i have a 232/234 with a 150 dry shot.
racetronix 255lph intank pump with hot wire kit and svo 42...plenty of injector left
Old Nov 12, 2008 | 05:59 PM
Frost's Avatar
a 200 hit with your setup could easily put you on the ragged edge with 42s
Old Nov 12, 2008 | 06:35 PM
FICINJECTORS's Avatar
Again you and I are in complete agreement Frost.
