Injector replacement
Old Sep 19, 2003 | 05:08 AM
Smoke_Ford's Avatar
Default Injector replacement
when do you need to replace injectors for an LS1? at about what HP?
Old Sep 19, 2003 | 10:39 AM
JF WS6's Avatar
Default Re: Injector replacement
I believe 450RWHP is about the limit for stock injectors......
Old Sep 19, 2003 | 02:29 PM
Smoke_Ford's Avatar
ok, thank you
Old Sep 19, 2003 | 07:48 PM
BYBYC5's Avatar
*Bad Trader*
is that for 28#ers or 26#ders
Old Sep 20, 2003 | 10:20 PM
Mike K.'s Avatar
I think it is the 28 #'s are at the limit at 450rwhp. The 26#'s would be a bit less.
Old Sep 23, 2003 | 04:56 PM
LS1M Author's Avatar
fwiw, my stock '00 auto z28 gets up to 85% at 5900 rpm WOT. By stock I mean lid, cold air & catback. Stock injectors, too - 26# I believe.
Old Sep 23, 2003 | 05:08 PM
Vents's Avatar
maxed some 26#'s out by 4500 on my truck motor, if that gives you an idea.
Old Sep 25, 2003 | 07:36 AM
Fast SS on TNT's Avatar
I ditched my 28's, and bought some 30lb SVO's which I think are about 36-38lbs in an LS1. When the new motor goes in, have to upgrade again.
Dont forget to upgrade your fuel pump as well. Why put in bigger injectors, and run a maxed out stock pump.
