what size injectors?
Old Nov 12, 2008 | 09:16 AM
adam120674's Avatar
Default what size injectors?
What size fuel injectors do I need to upgrade to on a stock ls1 running 8psi boost? Will I need to upgrade the fuel pump and fuel rails also? The A/R on the turbo is a .50. I donot know what the exhast side is. Thanks for any help
Old Nov 12, 2008 | 09:25 AM
BLOWNBLUEZ06's Avatar
42's should cut it, but I would get 60's. They'll give you room to grow.
Old Nov 12, 2008 | 02:57 PM
FICINJECTORS's Avatar
60's would be the route to go for sure.
I have the brand new Siemens 60lb injectors which will drop right in, flow matched, viton o-rings installed for $55 each.
Old Nov 13, 2008 | 03:38 PM
NAVY's Avatar
what about 850rwhp f1c 402 c.i.d What size fuel injectors do I need ?
Old Nov 13, 2008 | 06:58 PM
For that power level you will need to go low impedance 65lb Delphi, or the high impedance 75lb Siemens.
I have both, $79.95 each for the Siemens, $69 each for the Delphi.
But keep in mind, you will need an aftermarket driver box or an aftermarket ECM to use the low impedance Delphi's.
Old Nov 16, 2008 | 11:32 PM
Black35SE's Avatar
what would I need for a bolt on and cam ls1 camaro. Going to add a 125 shot of nitrous. Don't wanna run out.
