please help
Old Dec 8, 2008 | 11:43 PM
horse-power's Avatar
Default please help
I have a 98 camaro z28 that i'm replacing the fuel pump on. I was reading about the trap door method so I pulled my carpet back and low and behold it already had a trap door. I then pull the fuel pump out and it's covered in rust. I looked inside the tank only to find more rust so I tryed dropping the tank but the filler neck keeps hanging up. Is there a trick to getting it out without having to drop the rear? Is it possible to put a plastic tank in out of a 99-up? I know the 99-up require a different fuel pump than the 98 but thats not a problem because I'm buying a whole new assembly anyway. Thanks in advance
Old Dec 9, 2008 | 12:47 AM
code4's Avatar
You pretty much have to drop the rear on the 98's. I have got away with dropping it way down leaving the torque arm & lca's hooked up.
the new plastic tanks have a different sending unit so you would have trouble with your fuel level guage.
