Fuel cell
Old Dec 10, 2008 | 03:31 PM
67Firebird455's Avatar
Default Fuel cell
I planned to run an a1000 aeromotive pump, and my fuel cell has -8an fittings, but the pump comes with -10an's, question is, for 800-900rwhp, is -8an going to cause a problem? It's roughly 1/2", as opposed to stock 3/8 (67 bird), and -10an is almost 5/8". Any feedback would be greatly appreciated. Thanks!
Tony
Old Dec 10, 2008 | 03:55 PM
DevonsZ's Avatar
i have a 490bbc with 50lb injectors and had a a1000 on the fuel cell with two 8an supply fittings that i Y block in to one 10an fitting to supply the pump but on boost of 15psi i maxed my injectors and fuel pressure drop VERY fast at 5000 no where near red line and only made 655hp at 11-10.8 afr
Old Dec 10, 2008 | 04:59 PM
They claim the pump is good to 1000hp FI with -10an's.
Old Dec 10, 2008 | 05:57 PM
Fast_94_Z's Avatar
^^word
Old Dec 10, 2008 | 06:04 PM
9sectruck's Avatar
that was at the tires on a mustang dyno
the a1000 is 1000hp at the flywheel N/A isnt it?
Old Dec 10, 2008 | 06:18 PM
No, 1300BHP NA, 1000FI.
Old Dec 10, 2008 | 06:20 PM
Aeromotive #11101 Fuel Pump, Electric, A1000 Series, External, Universal.
A27-11101
These are the pumps that started it all. These A1000 fuel pumps are durable, reliable, and good looking, and they support high horsepower. Featuring a 600 lbs./hr. flow rate at 13.5 V and 45 psi, they are perfect for the daily driver that doesn't run like a daily driver.
Fuel Injected Engines:
up to 1300 HP - naturally aspirated
up to 1000 HP - forced air induction
Carbureted Engines:
up to 1500 HP - naturally aspirated
up to 1200 HP - forced air induction
Features:
ORB-10 inlet and outlet ports.
For EFI applications use regulator P/N 13101 or P/N 13109.
For carbureted applications use regulator P/N 13204.
Fully submersible for custom, in-tank placement.
Perfect for blow-through carbureted engines up to 1200 HP.
Billet Speed Pump Controller (P/N 16302) recommended for EFI street applications.
Old Dec 10, 2008 | 06:23 PM
If that's the case, the Aeromotive 11104 may do the trick, 800lb/hr flow -12an inlet, -10an outlet, should be good to around 1100rwhp.
Old Dec 10, 2008 | 06:25 PM
Or the pro series (althought not sure how long it'd last on the street), flows 1000lb/hr @ 45psi, and good for 1450BHP FI, 2000 EFI NA, with twin -12AN fittings. Costs twice as much as the A1000.
Old Dec 10, 2008 | 06:58 PM
HUNTER02SS's Avatar
I would go with 2-bosch 044's myself. I have always heard that the A1000 would overheat when daily driving with them. I could be wrong though.
Old Dec 10, 2008 | 07:15 PM
9sectruck's Avatar
i ended up with a magna fuel 750 it pumps the fuel now
Old Dec 10, 2008 | 07:20 PM
9sectruck's Avatar
The only prob. I have with the magna pump is the continues run time is only 30-45min on a cool day ,its hard to cruise with this pump and not see a pressure drop from the pump getting hot
Old Dec 10, 2008 | 07:21 PM
9sectruck's Avatar
I know this is not the sale forum but i have a a1000 pump with about 10 hours of run time if interested PM
Old Dec 10, 2008 | 07:24 PM
Ya know, I may just end up running twin 044's then, those units look like they'd be reliable since they're not working their *** off.
Old Dec 11, 2008 | 11:14 AM
Nasty N8's Avatar
Where did you get that? I have seen guys run it on trips 3-400miles. It is a great street pump.
Nate
