Ethanol in the gas ???
Old Nov 1, 2010 | 08:49 PM
armour's Avatar
I'm in the midwest and believe me, ethanol is not going away anytime soon. Someone else mentioned above that ethanol attracts water and is very corrosive-true. The only difference between the "flex fuel compatible" vehicles and the non is stainless steel fittings and non corrosive fuel line systems. Ethanol is actually a high octane by itself-over 115. Minnesota has been using a 20% ethanol blend for a number of years now. Here in iowa we see the 10% blend and some e85.
Old Nov 1, 2010 | 09:41 PM
NoGamesLS1's Avatar
Originally Posted by AutomagicLS1
Time to make the switch to e85
I have been running e85 for a few months now. Car runs great and put down some great number on the dyno with it. https://ls1tech.com/forums/dynamomet...acing-cam.html
Give it a shot, just make sure you have enough pump and injector
Old Nov 4, 2010 | 01:42 AM
sjsingle1's Avatar
Originally Posted by senicalj4579
how long have you been using it? I looked it up but cant find anything saying its sensor safe.
you can google startron....lots of info on their site....its even discussed on the bobs the oil guy site......used 1 bottle do far......you use 2 onces per 16 gals.....my idle has smoothed out a bit.....i am happy with it
Old Nov 8, 2010 | 04:21 PM
sjsingle1's Avatar
oops.........you use 1 ounce per 16 gals......i doubled it for my 1st bottle
Old Nov 12, 2010 | 04:04 PM
Pony Exp.305's Avatar
True..
Yes, I have read on other e-85 forum about that..Some do mix with 50% gas and 50% e85 into tank.
