e85 conversion...
Old Dec 13, 2008 | 04:49 PM
n20z28's Avatar
Default e85 conversion...
how do u convert ur car to run on e85? i have a 99t/a a/4 with a 370..11to1.. with 36lb injectors.... whAT is needed or can this be done... i would think 4 sure bigger injectors? but idk...
Old Dec 16, 2008 | 12:53 PM
Shoaf85's Avatar
Definately bigger injectors and possibly a twin pump set up. Then all you will need is a new tune, preferably from an experienced tuner!
Old Dec 20, 2008 | 12:07 AM
1MEANGTO's Avatar
You may be able to get away with your injectors. BVump your fuell pressure abot 5psi if you have a adjustable regulator. Also a good fuel pump or 2
Old Dec 24, 2008 | 02:33 PM
Schwanke Engines's Avatar
LS1TECH Sponsor
As long as you have a GSS340 pump, that will be fine. How much power are you making? Those pumps are good for 675 on gas, and 550 on E-85.
To make 550hp on E-85 with a 90% duty cycle you will need 54 lb/hr fuel injectors.
Again, I am not sure what horseposer level you are at, so those are the limits.
