Blown Alky SBC, can it run on E85?
Old Dec 16, 2008 | 01:43 PM
kc-unit's Avatar
Default Blown Alky SBC, can it run on E85?
SBC 377/6-71/alky injected.
What would need to change to have it run on E85?
I am looking for streetabilty here. I can not exactly run into Cheveron and top off with alky. lol E85 is a little more practical, although I know little to nothing about it.
Anyone have any idea on what I would need to change to have it run good on E85?
I can pull boost (larger pulley) and pull timing to make less power if it lets me run E85 when its not on a track....
Old Dec 16, 2008 | 08:53 PM
Casey2323's Avatar
Default sbc on E85
First of all.......... More specs.... Carbs/injection? ... what type of fuel system.. Pump... Lines... Barrel valve and Hat?... Your missing ALOT of Key details.........
Old Dec 17, 2008 | 04:03 PM
kc-unit's Avatar
377 with a littlefield 6-71
Ederlie Bird Injection, Enderlie 600 Pump, 8.7.1CR.
I am certain it can run on E85, would just have to rejet the BIRD. I was wanting to know how I can make it streetable.
But after doing some research it is highly unlikely that I will be able to run it on the street with this style injection, because it is a continuous flow pump, and its VERY difficult to run enough bypasses to be able to have it run decent at part throttle operation, and also WOT.
It looks like I would have to change a LOT of the set up up to get it in a position to run well on the street and track, in fact I would probably have to go with an EFI set up. There is the option of switching to dual carbs, and runing good ol Petrol, but I dont really want to do that, although it makes the most sense to get her on the street.
Bla!
Old Dec 22, 2008 | 01:26 AM
kc-unit's Avatar
TTT
any thoughts?
