Stock scale for 36# injectors?
so what should I assume about these injectors?
you'd probably be better off posting this in the computer and diagnostic' forum, but i think you need some more info here. if they're reading -1-2 on the LTFT's, you're ok. find out your injector flow rate in edit, and your actual injector size, and go from there.
