fuel system install ?
Old Dec 30, 2008 | 03:45 AM
jasond26's Avatar
Default fuel system install ?
I have a 01 RCSB silverado w/plastic tank and plastic fuel pump bucket. I purchased a magnafuel 625 pump. What do you guys recomend for the feed line from the tank to the pump. I was just going to get the aeromotive 3/8 quick disconnect and run -8 down to the pump but I don't think that will be big enough to feed the pump. I would like to keep the stock tank.
Will -8 be big enough to feed the pump and if not what would be a better option. Thanks
Old Dec 30, 2008 | 11:42 AM
Nasty N8's Avatar
You need to pull fuel from the bottom of the tank for that pump and we feed them with a large -12 line to the prefilter. I think a better option for your setup would be our dual Walbro pump assembly.
Nate
Old Dec 30, 2008 | 01:46 PM
jasond26's Avatar
I already have the 625 pump and -8 lines and fittings and -6 return lines and fittings so changing to a walbro setup is not an option.
