Injectors
Old Jan 6, 2009 | 09:26 PM
domestic disturbance's Avatar
Default Injectors
I am going to be intalling the polluter cam kit, as well as pulling my ls6 intake off and installing the bbk ssi intake and throttle body.... question is, I have a set up racetronix 42lb injectors that are laying around for my lt1 build, and was wondering if i should go ahead and slap them in the ls1....
Mods are
long tubes, cutout, 150 wet shot, slp lid...
with no tune would they beneficall?
thanks chris!
Old Jan 7, 2009 | 06:44 PM
back up for any advice!
thanks
Old Jan 7, 2009 | 07:04 PM
FICINJECTORS's Avatar
that is a TON of injector for your plans, but. They will work with a good tune, and you don't want to spend money on different ones since you have them.
Old Jan 7, 2009 | 08:00 PM
would they be worth going ahead and throwing them in for the time being and running untuned? I also have a set of ford flow matched 38's????
Old Jan 7, 2009 | 11:41 PM
you wouldn't be able to run either one untuned, you will flood the motor badly.
Old Jan 7, 2009 | 11:56 PM
JonCR96Z's Avatar
Just a suggestion. Could you link your website to your sig pic or just put a link in your sig.
Old Jan 8, 2009 | 05:24 AM
I was going to do that yesterday and it slipped my mind. I'll get on it.
www.fuelinjectorconnection.com
Old Jan 8, 2009 | 08:53 PM
405HP_Z06's Avatar
Here's the calculation. 42's are way to big, 38's are real big but closer. Both will work with the correct tuning.
