fuel setup question
Old Jan 11, 2009 | 11:01 PM
firefighting1101's Avatar
Default fuel setup question
im in the process of getting the car back together. its a 408 and hopefully should be putting down about 550 rwhp. i got an walbro 340 intank with the harness from nasty performance. i have a set of nasty fuel rails and 60# injectors. i was thinking about running my stock fuel lines with this setup, but am i setting myself up for failure? should i just run all new lines with a return? if anyone can give me some advice i would appreciate it
Old Jan 12, 2009 | 11:10 AM
Nasty N8's Avatar
As long as it is all motor you should be fine with the stock lines.
Nate
Old Jan 13, 2009 | 08:29 AM
its going to be on a 300 shot, but i have a stand alone to supply the nitrous
and should i run a return line?
Old Jan 13, 2009 | 05:26 PM
Nasty N8's Avatar
You should be fine without it. Of course it is always better and more control over the pressure if you do run a return line and add a good reg. up front.
Nate
Old Jan 13, 2009 | 08:15 PM
ok.. i have the reg, so a return line will be added as well. thakns nate
