Connecting fuel pump to fuel lines
. Thanks for anyhelp. the feed line should be marked "F"
the return (line from the T should be on the other side of the pump assembly)
you can pull the pump assembly out to make sure as it should be obvious which line comes from the pump and which line is the return and the middle line as the evac.
here is a pic maybe it will help as you can see the middle line comes from the boxes of the evac, and the line hard to plastic evac line goes to these evac boxes.
