--///*** Need some help ASAP ***\\\--
Old Oct 5, 2003 | 03:01 PM
glitch77's Avatar
Default --///*** Need some help ASAP ***\\\--
Im taking the tank out of my 98 Z to put in the Racetronics kit. How the **** does it come out? The neck catches before I can ever get it to drop enough? Im gonna kill myself.
PS. How-to books suck. They all must die.
(Sorry about the crazy title, but Im in a terrible mess.)
Old Oct 5, 2003 | 04:09 PM
SMOKINV8's Avatar
Default Re: --///*** Need some help ASAP ***\\\--
If you've dropped the rear end already...
You have to rotate the front edge down and pull it toward the passenger side. Keep in mind that you have to disconnect the lines before you get the tank lowered all the way.
Old Oct 5, 2003 | 06:25 PM
glitch77's Avatar
Dropped the rear? Its hanging... but thats it. Shocks are off.
Old Oct 5, 2003 | 06:43 PM
wrencher's Avatar
wrencher
Disconnect the bolt that holds the brake hose block to the rear diff.Then it will drop down even more, be carfull not to break a line though!
It will give you extra room to work with.
Old Oct 5, 2003 | 06:45 PM
glitch77's Avatar
I'll give it a look! Thanks guys!
Old Oct 6, 2003 | 09:39 AM
SMOKINV8's Avatar
Also, the shocks are the only thing that keep the axle from dropping down a lot further than they do. If you have a floor jack under the differential, you can disconnect the lower bolt on the shocks and slowly lower the rear end down until you don't have any more play in the brake lines (after you removed the bolt, like wrencher mentioned). That should give you enough room.
Old Oct 6, 2003 | 07:22 PM
glitch77's Avatar
Im getting there.
The Racetronics kit is great. Comes with everything you need. Top quality stuff.
