need help with fuel setup
Old Jan 27, 2009 | 05:28 PM
jasonpickett's Avatar
Default need help with fuel setup
Please put together a set up for me. I have a GMC Syclone that I am doing a 6.0l turbo setup. I am reunning a borg warner s480. I need a set up that is going to support 1000+ hp. I would like to keep the factory gas tank. I don't want to run a fuel cell if I don't have to. I want to run the aeromotive fuel rails. Also let me know about a good fuel pressure regulator for boost also. I would also like to know what size lines. Also should I tap fuel fittings onto the tank and run the lines and pump that way. Any information would be helpful.
Jason
Old Jan 27, 2009 | 08:23 PM
tsx153's Avatar
I would talk to Nasty Performance (a sponsor on the site) a real good guy and has great products!!!
Old Feb 3, 2009 | 05:52 AM
to the top
Old Feb 3, 2009 | 07:01 AM
405HP_Z06's Avatar
Aeromotive has great guidelines for systems. The A1000 system looks like your power range.
Old Feb 3, 2009 | 10:53 AM
Nasty N8's Avatar
There is no way an A1000 will provide the volume he needs for 1200-1300 whp. I sent an est. over you are going to need some way to pull fuel from the bottom of the tank whether the stock one is sumped or you go to a cell.
Nate
