Need a little help here please.
Old Jan 28, 2009 | 04:03 PM
charlie c5's Avatar
Default Need a little help here please.
Im running a 2002 WS6 with a 6.0 liter iron block and the STS rear mount turbo sitting at about 10 lbs boost. Its a daily driver but I like to play around every now and then. My question is fueling. I just replaced the fuel pump with the Wlbro 255 pump. The pressure at idle and crusing is around 50 psi. But if I step on it at all it drops to about 40. I have the SLIM 60 lb injectors. I was told that there are two different 255 fuel pumps a HIGH PRESSURE and a HIGH VOLUME pump. Which do I need for my application. And what should my target fuel pressure be.
Thanks guys
Old Jan 28, 2009 | 05:03 PM
FICINJECTORS's Avatar
you need more pump for sure, your target is 58psi
Old Jan 28, 2009 | 05:26 PM
SS1875's Avatar
Definitely need more pump....shouldn't see that drastic of a drop in pressure. Here is a sponsor that could help you out.
http://www.nastyperformance.com/FuelSystems.html
Old Jan 28, 2009 | 08:15 PM
charlie c5's Avatar
I just bought a new 255 walbro, damn I waisted that money???? Well, Ill call Nasty tomorrow..... Also, I just repllaced the fuel filter with one from Hi Lo oreily, is that ok, or is there a better one I need.?
Old Jan 28, 2009 | 10:38 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
50# at idle is a sign of an improper pump install, defective regulator or an internal leak (if you used a kit with a rubber hose you may have found your problem).
Regrdless, I doubt 1 pump is enough for the setup you are describing. If I can be of help, please give me a call. I stock many components to build your fuel system & can help you with a design to fit your needs.
