Fuel Pressure/Voltage Question
Old Feb 5, 2009 | 02:42 PM
Tirefire's Avatar
Default Fuel Pressure/Voltage Question
Is it possible that I’m loosing power at wide open throttle causing my fuel pressure to drop from 58 to 40 psi? I've had this problem for a while now and was wondering. If I'm cruising around the fuel pressure is steady, but one stomp on the peddle and the fuel pressure needle drops like a rock. I talked to one of the mechanics at work and he said that I might have to change the pulley on my alternator. Any help is greatly appreciated?
Old Feb 5, 2009 | 03:02 PM
FiredUpZ28's Avatar
Is the pressure regulator good? With your mods do you know what the spec is supposed to be?
Old Feb 5, 2009 | 03:18 PM
Tirefire's Avatar
I still have the factory setup. I'm on my second bucket so I can assume that the intank regulator works since the other did the same thing. It should be at 60 psi I believe.
