injectors
Old Feb 7, 2009 | 08:23 AM
quick16's Avatar
Default injectors
im building a 402 with foged bottom with a d1sc procharger will have meth injection will 60lb injector be enough with 14lbs of boost
thanks
Old Feb 7, 2009 | 11:21 AM
405HP_Z06's Avatar
From the calculation below it looks like you will be at almost 100 % duty cycle with the 60's (assuming your using a boost referenced fuel system). Take a look over here for some 75 or 83's.
Old Feb 7, 2009 | 09:29 PM
MotleyDrew's Avatar
my 403 ci with YSi and meth at 12.5lbs the 60lb motron injectors were at 106% with boost refernced fuel pressure regualtor and 45psi base fuel pressure. I have bought the new Ford 80 lb'rs to go with the 16+lbs
