Do you recognize these "30" lbs injectors?
Old Oct 17, 2003 | 08:52 AM
SSh's Avatar
SSh
Default Do you recognize these "30" lbs injectors?
These are supposed to be 30 lbs injectors, but I am not sure. The numbers on them are:
IW-058
0194/10
Sorry for the large pictures, but they show a lot of detail.
There is a W molded in the plastic top as well. The top is tan. I was told they were made by Walbro, but I did not think Walbor made injectors. They came in a FMS M-9593-B302 box which is for 30 lbs injectors, but I am not sure this is their original box.
Thanks,
Scott
Old Oct 17, 2003 | 09:37 AM
Vents's Avatar
Default Re: Do you recognize these
those are 19's i think. stock from the 5.0
Old Oct 17, 2003 | 03:52 PM
SDB's Avatar
SDB
Box number sounds right (I just got a set of SVO 30 lb's). Mine are a maroon/reddish color and dont look like the ones you pictured. I am soory to assume that you got ripped off?? I talked to a couple of other people that say their SVO's were also maroon/reddish in color.
SDB
Old Oct 17, 2003 | 06:34 PM
felton316's Avatar
5.0 stock 19#'s are orange in color.....
Old Oct 18, 2003 | 05:09 PM
ToplessZ's Avatar
First off these are not SVO 30's. Second, they're not Walbro. Third, there British. Here's a link to the injector from the manufacturers web site. http://www.mmcompsys.com/engine-fuelinjectors.asp Check out the data sheet. It's all metric, I think, so I couldn't make heads or tails out of the flow rate. Looks like it's a standard production injector for what I don't know. What ever they are they are probably not what you paid for.
JAY
Old Oct 19, 2003 | 01:32 AM
ChrisB's Avatar
According to the specs they are infact 30lb/hr nominally (~29.5) at 80% Duty Cycle. At 100% Duty Cycle they are ~38lb/hr injectors. (at ~43.5 psi)
Old Oct 19, 2003 | 11:39 AM
slow's Avatar
put a ohm meter across the terminals, and report the readings.
I know there are some low impedance injectors that are brown in color from the turbo SVO's with a rating somewhere between 30 and 38 #'s
Ryan.
