Removing Fuel Injectors... Write Up????
Old Mar 25, 2009 | 03:38 PM
TORCHD 02 TA's Avatar
Question Removing Fuel Injectors... Write Up????
Can anyone tell me how to remove the fuel injectors? I will be taking my stock 28# injectors off and be swapping them out with 42# injectors. But i have no idea on how to remove my stock ones first. Do i need to remove my FRs?
Thanks
Old Mar 25, 2009 | 03:55 PM
MeentSS02's Avatar
Kleeborp the Moderator™
The fuel rails hold them in place - the fuel rails are held in place with small bolts (4 if I remember right). Loosen those bolts, and you'll be able to pop the fuel rail off. The injectors will stay in the rails as they are held in with small clips (from the factory). Pop those clips off, and at that point they are only being held in place by o-rings. Just give them a gentle but firm tug and they'll come right out.
Very simple, but usually messy and smelly.
Old Mar 25, 2009 | 03:58 PM
MeentSS02's Avatar
I also usually put Vaseline or something on the o-rings before putting them back in as well...just thought I'd mention that as well.
Old Mar 26, 2009 | 03:32 PM
Thanks for the write up. I had no idea it was that easy.
What is the vasoline used for anyways?
Old Mar 26, 2009 | 04:16 PM
Viper's Avatar
"What is the vasoline used for anyways?"
To make sure the o-rings seat properly without tearing.
Also on some cars, the last bolt on the drivers side fuel rail (towards the firewall) has a cable stop mechanism (in case of an accident) attached to the fuel rail as well. The throttle cable should go through it. So there's a nut that goes on top of the cable stop mechanism, lift both off then you have to undo the bolt itself (like the other 3). Reading that it sounds more difficult than it is but I wanted to explain it as taking it off is easy, back on can be tough because you can't see all that well.
Old Mar 26, 2009 | 04:19 PM
1_bad_TA's Avatar
pull the rails and pull the injectors. I pulled mine with out a problem. Nothing special to do it.
Old Mar 26, 2009 | 04:29 PM
I jsut did not know what was involved pulling the rails off to get to the injectors
Old Mar 26, 2009 | 05:58 PM
02NBMWS6's Avatar
you'll need tuning immediately if you swap your 28s for 42s. Your car will run like crap due to all of the extra fuel
Old Mar 26, 2009 | 06:59 PM
I am swapping them at the tuners shop. I know the car will run like dog shiit
Old Mar 26, 2009 | 07:57 PM
98Camarod's Avatar
It will also be easier if you use a fuel disconnect and take the feed line off. They usually all stay on the rails when you pull it up. I think its a 3/8" disconnect.
Old Mar 26, 2009 | 09:55 PM
I have a cheap plastic 3/8" fuel line removal tool. I have not used it. Hopefully it will work
Old Mar 26, 2009 | 10:22 PM
MeentSS02's Avatar
It will - just slip it over the hard line, and seat it as far as you can into the fuel line connection point. Push forward on the fuel line (towards the passenger side), and then pull back. Fuel will come out. Your hands will smell like *** for the rest of the day. The end.
Old Mar 26, 2009 | 10:31 PM
Cool. Thanks for all the info
Old Mar 28, 2009 | 08:52 AM
98Camarod's Avatar
Sometimes you have to play with the feed line to get it to come off. Just have the rags ready to catch all the fuel. Some latex gloves take care of the fuel smell on the hands if you worried about it.
Old Mar 28, 2009 | 11:34 AM
koolaid_kid's Avatar
You will want to relieve the pressure also. Remove the gas cap to help.
Old Mar 28, 2009 | 11:46 AM
Yeah remove gas cap and de pressurize the shrader valve.
Thanks guys
