wont idle just changed o2 sensor
Old May 4, 2009 | 08:57 PM
orange1999ws6's Avatar
From: rochester ny/ cannon air force base, new mexico
Default wont idle just changed o2 sensor
Just replaced my o2 sensor on left bank got simulator for rear sensors is it possible to have a bad new o2 sensor that gives wrong reading which cause the car to spit and sputter and not even idle.... And I believe its running rich on just the left bank but not sure any thoughts?
Old May 6, 2009 | 03:52 AM
InsaneDomestics's Avatar
Does your car go from LOW Rpm to HIGH Rpm back and forth?
Old May 8, 2009 | 10:26 AM
not really just goes down to 300rpms and trys to idle... then it will go up to 900 and idle then if i hit the gas it drops down to 300 again and trys to recover or dies out... but we just recently discovered i have low fuel pressure.... so were thinking the pump is bad so im gonna replace it and hope that works....
