98 dual pump setup?
Old May 12, 2009 | 08:19 PM
Floader's Avatar
Default 98 dual pump setup?
I was starting to do my fuel setup the other day and was thinking about running -8an line all the way from the bulkhead on the top of the tank to the rails. What i want to do is drill out the factory return line an put a 90 degree -8an bulkhead fitting in, I am sure someone has tried/done this but i cant find it in the search. Thanks
Also wondering if anyone has used aluminum hard line with fuel injection, says something on jegs site about not for fuel injection?
Old May 13, 2009 | 02:50 AM
The Fugitive's Avatar
do a search for mightmouse's set-up also his sticky, he did a write up on his metal tank work. I will try to find the links but try doing the search for him if I don't get back to you in time.
Old May 13, 2009 | 06:06 AM
Floader's Avatar
the sticky just has what he did for the intank setup, i am looking for what he did for lines off the tank. Ill do some more searching....
Old May 19, 2009 | 08:40 PM
MIGHTYMOUSE's Avatar
http://rides.webshots.com/album/64988796cazkku?start=12
