injectors?
Old May 28, 2009 | 11:23 PM
Hotroddin's Avatar
Default injectors?
What would upping to some 30LB injectors on my stock 96 formula do for me? more power? anything?
Old May 29, 2009 | 12:06 PM
405HP_Z06's Avatar
They will only help if there is something wrong with your existing injectors or you need the additional fuel due to engine modifications.
Old May 29, 2009 | 12:23 PM
7th Darkness's Avatar
Injectors alone are not going to give you more power. The only way that injectors would give you more power is if you were maxing out the load on a modded motor causing the car to lean out. Upgrading to a higher flow would prevent this.
Anything to gain on a stock car.. not unless like said above there is something wrong with the ones you have now.
Old May 29, 2009 | 11:33 PM
Hotroddin's Avatar
thats what i figured, i was just curious, lol.
