Injector Upgrade
Old Nov 7, 2003 | 01:52 PM
mlkenjutsu's Avatar
Default Injector Upgrade
Hey Guys:
Just bought a set of 28.8# injectors to replace the 26# injectors on my 2000 Corvette Coupe. Will the stock MAF need to be replaced with a 2001-2004 MAF for these injectors to work properly or can I stay with what I have? Any help appreciated.
Thanks,
Mark
Old Nov 7, 2003 | 08:51 PM
felton316's Avatar
No, the MAF doesn't have to be replaced when swapping injectors. You must have had a mustang at one time or another? But running the injectors without changing the PCM tuning, it will run rich. The best thing to do would change the Injector Flow Rate table in the PCM with LS1-Edit. But such a small change in injectors, you can run them with no tuning, but you will be a little rich.
