running e85?
Old Jun 4, 2009 | 11:59 PM
SPOOLIN Z28's Avatar
Default running e85?
running e85 has ran through my mind plenty of times. what is entirely needed to run e85? do i need to run a standalone fuel management system? any info helps. thanks
Old Jun 5, 2009 | 12:06 AM
waterbug1999's Avatar
plenty of local gas stations that carry it, bigger pump, bigger injectors and a tune.
Old Jun 5, 2009 | 12:15 AM
got plenty of gas stations, got a pump, what size injectors for around 700rwhp?
Old Jun 5, 2009 | 12:19 AM
60's or bigger I would have to imagine.
Also, im sure you will need two pumps for that level.
Old Jun 5, 2009 | 12:27 AM
ive got a racetronix a1000. have not yet installed it. i have a set of 75lber's not yet installed either. just reading more into the e85 world. i am still finishing my new build. thank u for the info
Old Jun 5, 2009 | 12:33 AM
Good luck with your build.. I am really contemplating on switching to E85 as well, runs cooler and cleaner.
Old Jun 5, 2009 | 08:42 AM
A_VAS's Avatar
figure 30% more fuel than what you would need on gasoline. That's what mine takes with mild blower (6psi).
that pump and 75's should feed it. there's some good threads on here about figuring your AFR and etc.
