Injector Size and Fuel Pump.
Old Jun 6, 2009 | 11:04 AM
Lt1Porsche's Avatar
Default Injector Size and Fuel Pump.
What size injectors would you recommend for a 2000 TA with a Polluter cam, mildly worked 241s, pp 85 mm intake and TB, Lt's and 150 shot Nitro Daves plate kit? And do u think a simple walbro pump upgrade will be sufficient to supply what I need? Also my tuner is 30 miles away, would the injectors you recommend be okay to drive the 30 miles highway needed to get to the tuner. Im also running TR7 plugs so fouling can be an issue.
Old Jun 6, 2009 | 11:45 PM
Mike @ New Era's Avatar
Walbro 255 pump is a must, we have these in stock at $99 shipped. Also, I think 30lb injectors would be a good idea, also have the red tops in stock and on sale at $199 limited quantities. Give me a call on Monday and I can set you up with what you are looking for 585-865-1832. Also, TR7's are over kill, TR6's should work just fine for you, got those as well.
