over 500rwhp what pump?
Old Jul 6, 2009 | 04:24 PM
johnLs1camaro's Avatar
Default over 500rwhp what pump?
As of right now my car makes 380rwhp, I am getting it tuned on the bottle soon which should put a little over 500, maybe close to 550rwhp. I am needing a fuel pump that can handle that, Also didnt want to spend tons of money on one either. I didnt know anyone could help me out on a pump I need to look for thanks.
Old Jul 6, 2009 | 08:47 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
If you plan on staying around 550rwhp or less, then I recommend a single Racetronix kit with pug-n-play wiring harness.
Beware fo some of the universal kits that have problems with pump reliability & rubber hoses etc.
I keep the Recetronix kits in stock.
Feel free to contact me if I can be of additional help.
Old Jul 6, 2009 | 08:54 PM
well, i search around many places and see walbro 255 pumps, would I have any problems running something like that?
Old Jul 7, 2009 | 10:38 AM
Nasty N8's Avatar
Yes that is just a standard pump has not provisions for your stock setup. Get a direct replacement pump made for your car. Lonnie keeps them in stock as do I.
Nate
Old Jul 10, 2009 | 09:27 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
How about 575rwhp NA?
Old Jul 10, 2009 | 09:53 AM
LS1TECH Sponsor
Every car seems to be a little different, but most NA setups are run rather lean so you may be ok with a good single pump.
For example a 550rwhp supercharged motor at 11.5:1 AF ratio is a lot worse than 600rwhp NA at 13:1 AF ratio.
Feel free to call if you like.
Old Jul 10, 2009 | 11:50 AM
LS1Tech Co-Founder
I'll definitely call you when I decide how I am going to set up the fueling system.
Old Jul 14, 2009 | 11:32 AM
camaropilot's Avatar
How much HP will the walburo/ race tronics single pump set ups support for a N/A car?
Old Jul 14, 2009 | 12:48 PM
cals400ex's Avatar
most say around 550 with the new wiring.
Old Jul 14, 2009 | 02:00 PM
are the racetronix pumps pretty much a walbro 255?
Old Jul 14, 2009 | 07:21 PM
LS1TECH Sponsor
Yes they are Walbro 255's, but there are quite a few different models of that pump. All are not created equal.
The pump is not the only consideration. The mounting accessories, wiring & hoses etc., are what makes it a good kit.
Old Jul 14, 2009 | 07:47 PM
I saw a lot of your racetronix kits are around $230 or around that, I just dont understand, being a walbro 255 is $100 new. Im not knocking on you all or anything, just if the hoses and mounting hardware is what makes over a $100 difference i dont understand... Is there more that comes with your alls kits, that I just dont see?
Old Jul 14, 2009 | 08:31 PM
Dutchman427's Avatar
This is the next thing I got to look at purchasing. I am still running the factory fuel pump with my set-up. The car has less then 10k miles on it so that is why I did not change the Fuel pump when I did my build.
Old Jul 14, 2009 | 08:42 PM
elias_799's Avatar
i think it comes with the hotwire kit for that money, not 100% sure
Old Jul 14, 2009 | 09:11 PM
conan's Avatar
Your paying the extra $$$ for the plug and play from lonnie and the customer support. I got a dual pump set up from him and had to solder the stock wires (that I cut for my boost a pump that didn't cut it) back together. All his stuff pluged right up to the stock harness and has yet to drop 1 psi of pressure. I spent 600 on my set up and I would do it again with out hesitation.
Old Jul 14, 2009 | 10:50 PM
LS1TECH Sponsor
Yes, I include the wiring harness (hot wire kit) & various other options for that money.
The base pump with hose, sock, mounting kit & internal wiring is around $149.
Instead of speculating over this any further, you can call me & get all of your questions answered in a matter of minutes. I can be reached from 9:00am-11:00pm eastern time including weekends at 724-322-8505.
Old Jul 14, 2009 | 10:52 PM
^thanks man I was just wondering and wanted to hear some things from members also.im 21 and dont have a lot of money to waste.. I will give you a call tomorrow.
Old Jul 16, 2009 | 10:26 AM
MadIceV8's Avatar
Customizing Director
Racetronix ~150 plus ~60 if you want the hotwire kit (recommended).
Walbro ~100
Old Jul 16, 2009 | 11:57 AM
allthrotle's Avatar
Im running the racetronix pump with the hot wire kit. Im putting down right around 550
Old Jul 16, 2009 | 08:53 PM
elias_799's Avatar
^^ with 42lb injectors ?
