Leaded gas
Old Nov 15, 2003 | 10:42 AM
bigSS's Avatar
Default Leaded gas
Hey guys, i'm heaidng to the track tomorrow to test out my new NX kit. Since i'll be making a few runs on the 150 shot, I want to be on the safe side. Now, i've heard that leaded gas can be hard on 02s and cats, but i'm only planning on running a 5 gallon 50/50 mixture of some 93 and maybe 112. Should I be ok? My local shop is all outa unleaded stuff.
Old Nov 15, 2003 | 11:36 PM
wrencher's Avatar
wrencher
It WILL coat the O2's & degrade them ,maybe to the point where they are too slow & cause problems & codes.
It also coats the catalyst's & will decrease their efficency as well & the same possibilites of related codes .
I would never put any leaded gas in an EFI closed loop feedback O2'ed car.
Old Nov 16, 2003 | 11:53 AM
supersp0rt's Avatar
its not nearly as bad as some people are making out to be. will it eventually fry the o2's? yes. will it kill cats? yes. my guess is most people who are even trying leaded gas dont have cats and the o2's last longer than you think. ive run a mixture of leaded gas this entire year without a single problem. will they eventually go...sure, but its honestly not going to be a big deal. if you run one nights worth of leaded gas its doubtful it will harm a thing.
Old Nov 16, 2003 | 02:58 PM
BigPlanTransAm's Avatar
how expensive are 02's? dont they make lead resistant 02's? what kind of "problems" are we talking about when 02's go bad(other than throwing codes)?
Old Nov 16, 2003 | 09:58 PM
MOTRUBL's Avatar
Try and find some 100 unleaded. That should help. If your still a little apprehensive, add a bottle of octane booster. But you should be fine with the 100 ul.
Old Nov 16, 2003 | 10:14 PM
wrencher's Avatar
wrencher
If you ever seen in real time what an O2 does in relation to the oxygen content of the exhaust, you'd understand what I mean.
They degrade normally with use,add something known to coat the porcelin on the O2's, that is asking for it.
The PCM needs the fast reaction time to properly control fuel.
A coated with whatever O2 will not react as quickly.
It will effect LTFT & STFT.
If it gets slow enough, a poor O2 performance code will result.
If it's a race car who cares but your driver?
