37# with Heads/cam
Old Jul 11, 2009 | 03:06 AM
TransAmcoupe98's Avatar
Default 37# with Heads/cam
I have an 01 Z06 with AFR 205 62cc heads and a custom cam with duration around 228-230. Should 37pd injectors work well or maybe go a little smaller. 42pd are too big IMO,
Old Jul 18, 2009 | 07:23 PM
khaotic's Avatar
Default injectors
Are your 37lbs injectors rated at 45psi fuel pressure or 58psi either way they 37 should work just fine Just dont forget to scale them accordinly to the correct fuel pressure.
