Any Issues with Walbro 255s
Old Jul 30, 2009 | 10:23 PM
223HAWK's Avatar
Default Any Issues with Walbro 255s
Just got my car back for doing a Cam swap..At the shop the stock pump took a **** a day after the car was done. No big deal put a new pump in it, they said get a Walbro, they put a new one in. The stock one was jumping from around 30-50 lbs when it would work. The new one holds 60 all day. With the new pump it ran a day and I drove it an 1hr or so and parked it, now I have no pump..No pressure at the rail..odd how it works for a day and then nothing..Is it a chance that maybe the new pump is bad? Checked fueses, all good. Relays maybe?
Old Jul 30, 2009 | 10:34 PM
waterbug1999's Avatar
A buddy of mine that had a similar issue found out that the connection on the back firewall was loose... He just bent the female pins in a little so it would make good contact, not a problem since..
The last 2 years I have been thru 3 walbros, I since changed out to the racetronix fuel pump and harness.
Old Jul 30, 2009 | 10:39 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Pump could be bad, but it could be many things.
There are counterfeit pumps & also a few Walbros that are not suited for your application, though they are sold as a replacement for your car by various shops.
Also there are some kits out there whch use rubber hoses & also omit the venturi system. You get what you pay for.
Not sure what you have or how it was installed.
90% of the problems are from poor install or improper application.
I've had excllent luck with the Racetronix kits I've used over the years & only sell these kits for a reason.... they work & do not cause me problems.
Old Jul 31, 2009 | 01:32 PM
223HAWK's Avatar
Put a Relay in it this morning and seems to be fine so far but only time will tell..
Old Aug 12, 2009 | 08:52 AM
joshctr1's Avatar
Do not use the fule hose they provide. It will crack and break. Get you own
