evap question
Old Aug 4, 2009 | 04:44 PM
98camZ's Avatar
Default evap question
[IMG][/IMG]
do u really need this i have all of my egr and air pump all deleted, is there a way to block it
Old Aug 5, 2009 | 11:24 PM
98camZ's Avatar
any body have any part number for that little gray retainer clip that holds that on????
Old Aug 20, 2009 | 01:50 PM
BOONE's Avatar
Default evap questions
You have a canister on your fuel tank that is filled with carcoal that the tank vents into, you have to remove it and some other related lines. You would see once you removed your tank, and then just vent it to the ground like a bike, that is what I did to mine. At first I tried to put a tipover valve on it but then it would not allow me to fillup the tank, it was just like the filler was clogged with cement, when I put a k&n filter in place of the tipover valve and vented to atmosphere, it filled perfectly. So I guess its not just like a bike in that it vents to atmosphere meaning it goes up and is zip tied to my fuel filler neck in my wheel well up high and I have never smelled fumes. Then I believe we had to program it out of the computer if I remember right because it will through a code to remove it all. Boone
Old Aug 20, 2009 | 02:20 PM
JonCR96Z's Avatar
Just to put some info out there. You don't take that stuff off with a screwdriver. You pressed down on the grey clip and just slide it off.
Old Aug 20, 2009 | 03:39 PM
Big_Bird_WS6's Avatar
like this.
