Which wires?
Old Aug 7, 2009 | 12:05 PM
Boo"SS"t's Avatar
Default Which wires?
Does anybody know which wires specifically go to the factory intank fuel pump by looking at the wiring connectors underneath the car directly above the rear axle? I already took my intank pump out, but never bothered to mark which ones they are, I'm planning on using those to supply power to my electric scavenge pump for my turbos. I'm just trying to do it the easiest way or the lazy way. Thanks!
Old Aug 12, 2009 | 08:40 AM
joshctr1's Avatar
no clue
Old Aug 12, 2009 | 10:46 AM
Nasty N8's Avatar
Don't use the pump wires as they are not sufficient already for the fuel pump let alone more pumps....Use a heavy gauge hotwire kit with a separate relay to power it.
Old Aug 12, 2009 | 08:26 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Run a separate power feed as Nate stated.... You can use the grey wire to activate the relay for the pump.
Old Aug 16, 2009 | 11:22 AM
Boo"SS"t's Avatar
I guess, I should have also mentioned that I'm no longer using those factory power supply lines since I've installed a dual external pump and have two totally separate wirings and relays/fuses for each pumps, hence the reason why I wanted to use them to suplly power to my scavenge pump, like I've mentioned before...I'm just trying to do it the easiest and ofcourse, just because I'm too lazy to run a new wiringsfor it.
