Car died.
Old Aug 8, 2009 | 02:42 PM
dochall22's Avatar
Default Car died.
How can I test my fuel pump before I pull it out? I'm checked all the fuses, lines, etc but can / should I pull an injector and see if it's got any fuel comin out when i try to start it? I'm pretty sure it's the full pump.
Old Aug 8, 2009 | 03:19 PM
98 LS1 SC's Avatar
Do you hear the pump come on when you turn on the ignition? Check for pressure at the fuel rail schraeder valve.
Old Aug 12, 2009 | 08:37 AM
joshctr1's Avatar
Agree. Or take the line off at the fuel rail and turn the engine over. Requires those little plastic clips to remove line
