Fuel gauge randomly drops to E while idling
Old Aug 11, 2009 | 02:21 PM
blubyu02's Avatar
Default Fuel gauge randomly drops to E while idling
My fuel gauge randomly drops to E while idleing causing my check gauge light to come on. Is this from a worn out fuel pump? if so If i just change my fuel pump will that fix it? It stays on E then a few minutes after i take off it goes to whatever the level of fuel is in the car. any help would be appreciate thanks
Old Aug 11, 2009 | 03:03 PM
Nasty N8's Avatar
The level sender is going bad if you replace the entire pump assembly it will have a sender on it or yu can get just the sender.
Old Aug 11, 2009 | 08:58 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
You can do a Racetronix plug-n-play pump/wiring harness, plus a new level sensor for less than a GM replacement pump costs.
I have the pumps in stock.
joesscamaro252's Avatar
It'd be cheaper just to do the fuel level sensor
Old Aug 11, 2009 | 09:00 PM
LS1TECH Sponsor
If you are running a modded engine with a 150 shot, a better pump is a good suggestion anyway.
Old Aug 11, 2009 | 10:15 PM
blubyu02's Avatar
Lonnie do you have a replacement sender in stock as well? i found this part number is this the kit you are speaking of? RX-F99-GSS340-FPKG-2
Old Aug 11, 2009 | 10:27 PM
LS1TECH Sponsor
I can ship you a level sender with the pump assembly if interested.
I can get one in a few days, from the dealer.
Please call to discuss at 724-322-8505.
