racetronix hotwire kit?
Old Aug 12, 2009 | 03:42 PM
mean94lt1's Avatar
Default racetronix hotwire kit?
i just bought the pump and hotwire kit off lonnies performance great guy to deal with....i was wondering where you guys mounted your relay and if you ran the wire inside the car or underneath....also did you hook the wire to the alt or go directly to the batt i did a search but no direct results of what i was looking for pics would be appreciated just want to see what you guys did with your setups on a ls1 car also 99 and up
Old Aug 12, 2009 | 08:20 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
If you have questions, please call.....
The relay can be mounted near the wiring connector behind the dr. side seat (near the brake line bracket) & run the wires forward with the fuel lines, crossing up over the trans & coming to the front pass side of the engine compartment.
Alternator or battery is your preference. Both work equally well & are only 1ft apart.
