fuel pump???
Old Aug 12, 2009 | 05:08 PM
VIPER EATER's Avatar
Default fuel pump???
hey guys well i got a quick question for ya. in my camaro i installed a walbro 255 right before my 408. and the other day i got a tip that my FPR might be bad, so i got it to a buddies house and hooked a gauge to the rail and turned the key and the pressure went straight up to 62lbs. but when the fuel pump relay clicked off the pressure dropped right away. so i checked the rail on my buddies GTO and after 15 min of the key being off the pressure was still over 40lbs. so i got a new fuel rail and installed it and it still does the same thing except it takes probably 2-3 seconds before its down to 0lbs. so my question to you guys is, is the fuel pump itself bad or what else should i look at? any help or thoughts would be much appreciated
thanks jason
Old Aug 12, 2009 | 08:10 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
There is a good chance the line on the fuel pump you installed did not seal properly. Was it a factory type corrugated hose or rubber?
Old Aug 13, 2009 | 04:16 PM
to be perfectly honest with ya i dont really remember its been about 4 years since the pump was installed and this is the first year i have had with this problem
