help with fuel setup
Old Aug 31, 2009 | 03:07 PM
02' hawk's Avatar
Yes. I'm wondering if i can run 2 racetronix pumps and keep the msd boost-a-pump on there. It currently has it on there and 1 racetonix fuel pump.
Old Aug 31, 2009 | 06:17 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
The Racetronix pumps I offfer are different than those in the 99-up f-body kits.
Also with a properly designed setup, there is no need for a boost-a-pump.
Besides, my dual kits are already proven beyond 1000rwhp.
Old Sep 13, 2009 | 04:18 PM
02' hawk's Avatar
Originally Posted by Gen414
Here ya go (good for over a 1000HP)
I'm going to do the dual intank setup. My question would be: Does the fuel get regulated after the fuel rails like shown in the picture or would you put the regulator in front of the fuel rails to regulate? I have the Magnafuel 9950-B reg.
Not sure if i run the fuel lines to the front side of the rails then put the regulator on the back side of the rails then to a return OR put the regulator in the front side of the rails with the return there?
Old Sep 13, 2009 | 06:07 PM
02' hawk's Avatar
Is the Walbro 255lph the same as the Walbro 340?
Old Sep 13, 2009 | 08:11 PM
LS1TECH Sponsor
A walbro GSS340 is a high pressure 255lph pump. There are quite a few different ones (GSS340's) though.
As for the regulator, you should feed the rails, then regulate after the rails like shown. No real need to y the 2 rails in parallel. Series works fine in applications well over 1000rwhp.
Old Sep 15, 2009 | 12:18 PM
02' hawk's Avatar
Do i pull out the regulator inside the tank if i'm going to do a dual pump setup with a front mounted regulator?
Old Sep 16, 2009 | 08:39 AM
Gen414's Avatar
I would, yes.
