Drill out factory regulator?
Old Sep 23, 2009 | 11:27 PM
brandon1566's Avatar
Default Drill out factory regulator?
I was told I could drill out the factory regulator on my truck rails somehow. Anyone know how to do this?
Old Sep 25, 2009 | 12:48 PM
Nasty N8's Avatar
How are you planning to regulate the pressure?
Old Sep 30, 2009 | 01:25 AM
aeromotive a1o00 regulator, futral mentioned drilling the factory regulator out im not quite sure how to accomplish this.
Old Sep 30, 2009 | 11:32 AM
Nasty N8's Avatar
Be careful with the Aeromotive stuff it has caused alot of headache with fluctuating pressures. I am not real sure how to "drill" it out either. You could remove it but would need to plug the vacuum port. And how do you plan to run a return line on the rails? The schrader valve is not a good port it is on the same side as the feed and can leave the pass side starve.
