Inline and intank fuel pump discussion
Here is the debate:
If you take Pump A(intank) rated at 255lph @60psi and Pump B(inline) rated at 190lph @ 60psi, would you, under ideal conditions, actually have ~445lph @60psi, or would Pump B cut your flow back down to 190lph @60psi due to the fact that it is only rated to flow at that?
Tim
if you put two in series (head to tail) it will be twice as bright, but last only as long as one batterly.. if you put them in parallel (side by side) it will only be as bright as one, but last twice as long
for you the brighness is pressure and the lasting time is flow.. we have a regulator which holds pressure constant, so flow is what you want to increase.
maybe that helped?
I'm trying to figure out who's right and who's wrong in my debate with someone about putting 2 pumps together and what the outcome is.
look at the chart below, i dont know what the stock pump is but lets just say it is similar to the307 like the chart or at least will have similar charistics but at lower numbers. at 60psi it will flow about 50gallons per hour, that is the presure if it has to feed the injecotrs. if you lower that to 5 psi(the presure that would be needed to just pump gas to the inline) the volume goes up to about 73 gallons per hour. the numbers are not exactly right but you get the idea, i would be money that a stock intake pump at 5psi can flow the same volume as a gss340m at 60psi.
http://www.gnttype.org/techarea/fuel.../fuelpage.html
the only way that smaller 190 pump would help is if you ran it parallel some how, inline i think it would be a restriction
Again good topic,
J
I left the inline in because I thought it would be a good thing to do. Guess not? Yeah if I needed more I would go with the dual intank racetronix set up like my bro has in his 95 formula. I also need to get rid of my FMU but that is another topic that I will start when I get pics of how its set up.
J
Adding the 255lph IN-LINE pump will allow your fuel system to pump more fuel though so it would be beneficial .
However , if you had the higher flowing pump in the tank and the 190 in-line , then you would be hurting your fuel system . Make sense ?
One more thing , if the 255lph pump you are talking about is efficient to 60psi , then you are talking about the GSS307 , which is good to 550 horsepower .
