EV14 injectors w/ ls2 intake
Old Oct 26, 2009 | 07:03 PM
Woody73z's Avatar
Default EV14 injectors w/ ls2 intake
Ok so i bought these 1000cc ev14 injectors and I thought they were saposed to drop right in.... They seem to short. When i bolt the rail onto the intake the injectors feel loose then you can push on them and they will " snap" in but come back up pretty easy? Is this normal? Do I need something else? Thanks for the info.
Old Oct 27, 2009 | 12:14 AM
FICINJECTORS's Avatar
what o rings are on the bottom.. if they are green or black 14, you need to get ls2 or ls3 16mm bottom o rings,, they are orange.. if you have the stock ls2 injectors you can swap them. call me if you need them
Old Oct 27, 2009 | 05:01 PM
Woody73z's Avatar
They are green yeah I need the bigger ones thanks for the replay i will give ya a call!
