08 Silverado Fuel Injectors I want to turbo my 2008 Silverado 5.3 non flex fuel. What style injectors does this truck run? Can I run ls7 injectors? Also does anyone know what size flex fuel injectors are and will they fit? |
Originally Posted by b18c1hybrid
(Post 12459125)
I want to turbo my 2008 Silverado 5.3 non flex fuel. What style injectors does this truck run? Can I run ls7 injectors? Also does anyone know what size flex fuel injectors are and will they fit? The injector is 47 mm o ring to o ring and the ls3 or 7 injector is 40mm. We make rail adapters to make up the space. The plugs are the same USCAR. The ls 3 injector is 42lb at 4 bar (58psi) Depending on the boost it will work well. If you are going with over 7lbs i would get our ls2 60's which are 48mm tall. I hope this answers your question.. Jon |
© 2024 MH Sub I, LLC dba Internet Brands
